RX-8 3rd sample
Auburn, CA
2004 Mazda RX-8
Oil OEM Redline Redline
5w20 5w20 5w20
Oil added 0 0 0
Miles on Oil 1250 1764 1500
Miles on Unit 1250 3014 4520
Date 12-13-03 12-30-03 02-09-04
Aluminum 9 5 5
Chromium 4 5 6
Iron 30 30 33
Copper 18 22 15
Lead 1 2 0
Tin 0 1 4
Moly 480 471 578
Nickel 1 1 1
Manganese 0 1 1
Silver 0 0 0
Titanium 0 0 0
Potassium 0 2 5
Boron 137 71 37
Silicon 42 28 21
Sodium 8 15 18
Calcium 1724 2421 2565
Magnesium 5 6 7
Phosphorous 850 1015 1084
Zinc 884 1236 1165
Barium 1 1 0
SUS Vis@210C 50.3 50.9 53.4
Flashpoint F 335 325 340
Fuel 1.5% 1.5% 1.3%
Antifreeze 0 0 0
Water 0.0 0.0 0.0
Insolubles 0.2 0.3 0.4
quote:
Originally posted by zoomzoom:
I thought that Synthetic are not suppose be used in rotary engines...Did that changed with new RX-8?
Also, doesn't the rotary engine burn a metered amount of oil? If that's the case, I surely would not use an oil with levels of ZDDP higher than current API GF-3/SL limits. You're asking for combustion chamber deposits and spark plug fouling if you do.
Thanks for the update.
Our cars still look pretty much the same on wear metals, but yours is looking better as far as fuel dilution and viscosity go.
What kind of driving do you typically do? Maybe I just need to run mine a bit harder.
I had to check a map to see where you were located, but wonder if you have seen any emulsion on the dipstick? Maybe not since no water was reported.
Why are you changing the oil out so soon? There has been some discussion around in here that talks about the cons of changing out oils too soon. This may be a candidate.
quote:
Don't forget, because of the oil cooler and associated plumbing on these cars, their owners have mentioned that something like 2 or even possibly 3 quarts of oil get left behind when the oil is drained.
I run 25% city and 75% highway on average. I hit 9000 RPM at least three times per tank.
At the very end of the last sample I installed a computer with a new fuel map that runs the RX-8 much leaner and that should bring the fuel dilution down.
The plan is to change the oil every 1500 miles until 6000 miles, then every 3000 miles after that. The reason is two fold. First the RX-8 only changes half its oil capacity and the second is the fuel dilution from running so rich.
Vince
Vince,
I see from the post at RX8Club that you have gone with the Canzoomer Stage I kit. This is good to know for future comparisons.
I agree that it should help lower the fuel dilution. Could be worthwhile for that alone.
[ March 02, 2004, 06:03 PM: Message edited by: molechaser ]
At the Mazda dealers the other day and had a look at their special oil for Rx-8. It is a synthetic import from Japan (a Castrol oil I think?) and says on bottle, "synthetic & semi sythetic oils are not to be used in pre-Renesis motors"
Break-in?
