Ok, it is our vacation tiny house on wheels (RV). I've documented this elsewhere, I thought I'd bring it to BITOG as well.
This project suffered from tremendous scope creep from what I had intended. Most new RV's these days come with 12v compressor fridges, and my main goal was to be able to prep for a trip and not need to plug the camper in to shore power. 400 watts of solar panel and a good AGM battery will get that done. The camper came from the factory with a 50 watt panel, which made an excellent battery tender during downtime, but didn't quite have enough to run the fridge long term and keep the battery charged.
Where we ended. *sigh*
6 - 200 Watt Panels (3 - Bifacial and 3 - Monofacial, as an experiment)
3 - 150AH LifePO4 Batteries
1 - Victron Multiplus II 3000VA Pure Sine Inverter/Charger
2 - Victron MPPT Solar Controllers
1 - Victron DC/DC Charger
1 - Victron Cerbo GX Communication Hub
2 - Self-Designed 3d Printed Fan Grill (As well as 2 downloaded vent grills)
1 - 7" Touchscreen control panel with 3d Printed mount
100 Feet of 8AWG cable (Estimate)
15 feet of 1/0 Cable
50 Feet of 8AWG Marine Triplex
A few pics:
Solar Controllers Pre-wired with some car audio power distribution I've had for 20+ years, ever since I worked for the company that made them. The solar controllers are self-explanatory. The DC/DC converter just takes the voltage/current from the truck's 7 pin harness and provides the proper charging profile for LifePO4 batteries instead of whatever it is Ford sends. Not strictly 100% necessary as the solar controllers will generally keep things running properly, but hey, we're gilding lily's here, so might as well.
Charging/Testing the 3 - 150AH LifePO4's. The paint marking on them is the last 2 digits of their MAC addresses so I can keep them straight in the monitoring app. (Bluetooth)
Panels mounted on the dirty roof, which I'm planning on cleaning tomorrow. White gets dirty fast....
3d Printed fan grills preparing to be mounted.
I didn't feel like spending $250 for the 'official' Victron 5" screen, so a $49 touch screen and 3d printed case are doing that duty.
3000VA of pure sine wave goodness
Installed, powered vent fans for cooling on left.
Safety...errr 1st? 3d Printed 120V cover.
Now, some nifty things I can do, mostly based around the Victron Inverter/Charger.
I can:
Limit the amount of current I pull from shore power. So if I am hooked up to a 15 amp normal house outlet and want to run the AC, I can do it, the rest of the current needed to make up the load is supplied by the batteries, and when the load drops, the batteries are recharged.
This also comes in handy at campgrounds that have crap 30A plugs. I can choke the current down and keep from melting the plug on my surge protector (again).
There's enough reserve capacity in the batteries that we can stop for meals and run the AC for 60-90 min, OR pre-cool the camper on our shorter weekend trips before we get to the campground. That's without any solar or truck input. On a good sunny day, that time will increase.
I can also prioritize solar, meaning the inverter will use all of the solar and pull from the batteries until they reach 30%, at which point it will supplement with shore power. If the load decreases to the point where solar can charge the batteries, it will shift that power to them. If I need the batteries at full capacity, I have the option of pushing a button and it will charge them from shore power.
This is the electric heat and water heater in the camper running with the shore power restricted to 20 amps and a super tiny amount of solar flowing in.
This is no shore power, all battery. The camper will never ever run this way. If we are without shore power, the heat and hot water will be propane powered. I just did it as a system test. The inverter never blinked.
I also have the provision of shipping power out of the RV through a 30a RV plug. I have been using it to power the mini-split in my master bedroom. As long as the days are sunny, it has been working great. I'll probably use it to run christmas lights or the fridge in the house this year as well since I have that wired to my transfer panel.
A few pics:
I can:
