..... but that's why i like the idea of creeping oil - cavity waxes coat metal, but they and high viscosity sprays may not make it into the depths of the mating areas where metal parts converge and are welded, and some of those spots are where rust starts first. The challenge is staying power versus something that is tortuous enough that moisture creeps in and can't easily dry out...
Reading many of the rust proofing threads here, many people assume that thicker is better, especially in high wash areas. I wonder if this is wrong thinking? The Carwell site claims that their product leaves a micro thin coating. I know my Krown seems to wash off the high wash areas soon after an application. However, when I rubbed my finger on some of these areas 6 months later, there still seemed to be some kind of film there.
Maybe the idea of seeing a thick layer is just a mental stigma that we need to get over.
Carwell: "The ultra thin film creeps and crawls into seams, cracks and crevices where corrosion begins and provides and active barrier between the metal and the causes of corrosion. Once Carwell has reached the good metal, it sets up a bond. This bond is at a molecular level and the film that is created is ultra-thin providing long-term protection. The inhibitors, meshed together in a chain link, are then used by the environment – contaminants, salts, etc… - before the metal is rusted."
My Saab was the first car we had krowned. I expected the spray in the wheelwells to be gone, but years after, there was enough material on the surfaces (struts, exposed fender metal, etc) to still bind sand and fine road dust.
Ymmv.
