Lately, I've been having issues with rust in the Jeep's coolant. The Jeep came with old school green (and a pretty clean cooling system). I flushed it and changed it over to G-05 about 3 years ago, a few months after I got it. For the last year or two, I've been noticing a good bit of rust buildup in the system, mostly in the radiator neck and overflow bottle (not much rust comes out when draining the coolant).
I last flushed the system in April, so the current fill of coolant is only a few months old, yet the recovery bottle has a bunch of [censored] in it. The Jeep has no issues with air in the system, doesn't lose any coolant, etc. The coolant also smells fine and is still clear.
For reference, the motor is iron block and heads, aluminum intake manifold, the radiator is aluminum, there's steel t-fittings in the rad hoses for e-fan temp sensors (the rust could be coming from these), the heater core is aluminum (new core, the old one was copper/brass). I had the heads off the motor last summer at 136k miles and there was a light rust film in all the coolant passages, but no flaky rust or anything concerning.
The buildup in the system doesn't seem to be causing me any cooling problems, but it definitely bothers me. At this point, I'm just wondering what might be causing it and whether I should flush the system and change to a different coolant type. Any suggestions?
