Originally Posted By: Warstud
Originally Posted By: SubieRubyRoo
Don't use deionized because guess what? It will leach ions from metals in your cooling system.
Where did you hear that? I think most Anti-freeze manufactures use DI water. I personally think either one is fine.
Using a pre-mixed Anti-freeze product that is made USING DI water is fine, because the added chemicals will 'fill in the gaps' so to speak.
Running straight DI water in a car's cooling system with nothing else is a totally different thing.. and I would only even consider using it for a VERY short-term flush.
