Hi,
I'm from Singapore and this is my 1st UOA
Car: Oct 2003 Nissan Sentra
Engine: 1.6litre QG16DE
Car condition : Completely stock
Driving style: Gentle
Climate: Warm, typ 30 deg cel, rel humid 80-90%
Oil: Royal Purple 10W30
Oil in service: 3.5 months
Miles on Oil: 3977
Miles on engine: 9877
Oil capacity: 2.7 litre with filter change
Oil added: 0 litres
Oil filter: original nissan
Sampling method: mid-stream oil from drain plug
Lab: WearCheck, ALS chemex
Metals, ppm
Aluminum, Al 4
Copper, Cu 9
Chromium, Cr Iron, Fe 8
Lead, Pb 15
Tin, Sn 1
Nickel, Ni
Contaminants/Additives, ppm
Silicon, Si 18
Boron, B 8
Sodium, Na 6
Potassium, K Phosphorus, P 1011
Molybdenum, Mo 109
Magnesium, Mg 26
Calcium, Ca 2287
Zinc, Zn 1217
Physical Test
TBN, D-2896 5.6
Water, % by FTIR Nitration, Abs 8.2
Vis, cSt@40deg 74.4
Glycol, Abs Petrol, % by dis 0.6
Sorry, the lab did their "standard" test for gasoline engines which didn't include oxidation, Vis@100deg or soot.
Any comments ? Thanks
Miles on Oil: 3977
Oil added: 0 litres
Metals, ppm
Aluminum, Al 4
Copper, Cu 9
Lead, Pb 15
Tin, Sn 1
Nickel, Ni
Silicon, Si 18
Boron, B 8
Sodium, Na 6
Molybdenum, Mo 109
Magnesium, Mg 26
Calcium, Ca 2287
Zinc, Zn 1217
Physical Test
TBN, D-2896 5.6
Vis, cSt@40deg 74.4
