Scrubcadet10
Thread starter
Oreilly got rotella in stock now, I bought 2 cases (6 gallons)
Same at the Concord NH WMMore like NomoreTella. My walmart is out of all diesel oils in jugs. just some quarts.
Your HF store sells Rotella??Harbor Freight had plenty where I’m at. The only thing that kept us from getting it was the $19.99 a price tag. That’s the same price it is at the truck stops.
Mine does two, the also carry individual quarts of PYB in 5W-30 and 10w-30 and STP 10W-30 small engine oil.Your HF store sells Rotella??
Yep. I knew they sold Pennzoil but when I was there earlier saw the Rotella and was surprised. Probably going to go back and get it since we need more.Your HF store sells Rotella??
if you need like 6 more gallons, I'd consider just putting it back and trying another more available oil for this OCI, Is the Providence in stock at your local Rural King, it's only $10/gal in 2 gal jugs and 5 gal buckets, to buy a whole OCI worth is the same price as 5 gallons of the HF marked up Rotella.Yep. I knew they sold Pennzoil but when I was there earlier saw the Rotella and was surprised. Probably going to go back and get it since we need more.
I have told dad about that. He doesn’t want to use anything but Rotella he is old school and thinks it will cause issues by switching brands which I have told him isn’t true but he doesn’t want to listen. Last time he used Valvoline Blue or whatever it is but he swears it caused it to use more oil. All the store brands seem to be in stock around and we have found a lot of Delo as well. I don’t think he will change the brand from Rotella.if you need like 6 more gallons, I'd consider just putting it back and trying another more available oil for this OCI, Is the Providence in stock at your local Rural King, it's only $10/gal in 2 gal jugs and 5 gal buckets, to buy a whole OCI worth is the same price as 5 gallons of the HF marked up Rotella.
Local Walmart has zero inventory of Rotella 5W-40 for at least the past 90 days.
I found online 5w-40 full synthetic alternative oils though.
They tired it here and it was a pretty big flop, Advance Auto blew out the gallon jugs of Rotella 0W-40 for $5.95, out of the 15 or so jugs of it I picked up, most of them had been sitting on the shelves for years untouched, several were in the old style packaging they stopped using around 2016.No shortage at my Canadian Tire. Also, I took this photo to show that 0w40 HDEO is common in Canada.
May have to check mine. good to know.\Yep. I knew they sold Pennzoil but when I was there earlier saw the Rotella and was surprised. Probably going to go back and get it since we need more.
