Rotating Full Synthetic with Conventional Oil
Is it OK to rotate between full synthetic and syn blend and/or conventional oils?
I went to an out of town Walmart and they have Super Tech full synthetic for only $14.36 for 5 quarts so I bought one.
Their ST conv is $13.68 for 5 quarts.
I have a 5 qt jug each of NAPA SB 5w30 and 5w20.
I like ST oil tho I won't need an OCI for 6 months.
I just did one a few days ago.
And if I do run full synthetic, it's OK to run an OEM, Federated PG241F, or Fram PH3614 filters with it?
dribble i few drops of each to mae a frankenbrew.
switch all you want, your engine wont mind at all.
Make your own syn blend.
Sounds like a plan.
IIRC someone posted that conventional and syn WPP oils have the same ad pack. If true you could mix 50/50 and get a 75 percent group 3 without any concerns about mixing additives.
Edit...
Forgot you said you had NAPA oil in the mix. No big thing. Switch away.
