I am thinking that my '96 windstar pics should be pretty close to your '95 Taurus, as far as how things go together.
Tosh:
Shop that did my last brake job (dealer) got carried away with anti-squeel.....and it got onto the rotors / pads.
Brakes really don't work well when that happens.
I decided to try not using it.....and they have been very quiet.
So...it is worth taking notice....be carefull to not over-do the lube.
I know that this is a Lube site....but lube on brake surfaces is not a good thing.
If linings (pads or shoes) become contaminated with any lubricant....they are no longer any good, and must be replaced.
Disk brakes are easier than drum brakes....although problems can come up with any repair job.
Make SURE that your wheel lugs are torqued in a "star" pattern to the correct torque for your vehicle.
If the lug nuts are not correctly torqued, and the same, it WILL cause the rotor to warp.....and you will feel it whenever you use your brakes. It will also cause your vehicle to not brake as well, and the pads to not wear evenly (as in one or more pads wearing out fast).
Tosh:
