Originally Posted By: d00df00d
Originally Posted By: Seventh
Pretty common to see S52 motors with very slow HG leaks. One of the classic symptoms is sputtering and misfires upon initial start up after sitting overnight or more, clears up after revving the engine a bit. Yours do that?
Not as far as I can tell. It's a bit jerky on throttle transitions, but it's like that at all temps. I figured there's probably something electrical to blame for that.
There's no white smoke or sweet smell from the exhaust, either.
Good. Your complaint about WOT behavior makes me think ignition though. There are only two acceptable spark plugs for this app, what do you run? Easy enough to check the resistance of the coils and plug boots too, but that alone isn't going to tell you everything. New Bosch coils ain't cheap but are easy to swap, got a buddy with a similar car? Have you checked the torque on the plugs? I went to change my (S52) 332ti's plugs and found three loose! Car ran great but even better now!
Edit: On the other topic, it would also be worthwhile to pay a competent shop with a smoke machine to do a leak test on the intake/crank case, and know definitively whether or not you have a leak.
