This is a very good UOA.
A few things to note, and a question or two.
1) your wear results are very good for 12k miles, and it looks as though 15k miles is very plausible.
2) your OCI plan confirms that high-end synthetics are quite capable of extended OCIs
3) your filtration is doing well, but I don't think that it's any better than what a lot of filters can do. This is typically a result of the contamination rate. A tight, well-running engine simply won't soot up much. Your daily driving pattern gets everthing up to temp and it stays there; no reason to expect high insolubles. Therefore, no reason to praise a filter that isn't being heavily tasked. Your Green filter isn't doing a poor job, but it's also not doing a great job. Your engine is tight and running clean; that is what deserves praise. You mentioned particle counts, but were you referring to the insolubles from the Blackstone UOA, or did you actually get PC counts done and didn't post those results?
What is the "normal" OCI per the OEM for this engine? Is it 5k or 7.5k? Just curious, because it makes one ponder the cost ratio for the ROI.
Let's say you can safely go 15k miles on your RL before you OCI. I have no idea what you paid for the RL, but I suspect it wasn't cheap. Are you getting 2x or 3x the ROI as compared to a quality conventional product? That is where people typically loose all sense of value when comparing/contrasting oil analysis and longevity. It depends quite a bit upon your OEM OCI recommendations.
If you can go 7.5k miles on conventional oil, then you would only need two OCIs to equal your RL 15k miles. At 5k miles for conventional, you'd need three OCIs to equal your RL. Since you can get about any quality conventional on sale for $2/qrt at Walmart (currently it's QS for $10/5 qrt jug), the 15k miles on conventional would be equal $4/qrt. Or, at 5k mile intervals, it would be $6/qrt. What does your RL cost over that same 15k mile duration? Even if you're getting RL for $6/qrt, you're only breaking even compared to conventional at 5k mile intervals. If you're paying more than $6/qrt for the RL, then you're not even at the break-even point!
You certainly are not getting "better" wear protection with RL. You are getting "longer" wear protection with the RL. You can get the same wear results via shorter OCIs with conventional products.
So the real question becomes this: are you extending out the RL far enough to surpass the ROI?
There is one benefit to extended OCIs that, for some people, understandably makes a difference, and this is the matter of convenience. If you drive a lot (say more than 20k miles a year) then often using synthetics and extending the OCI saves time under the car. For some people, that savings is worth the extra cost, even if the ROI isn't exactly balanced out. I can see the validity with respect to this for some people. They consider the cost of the oil worth the extra price paid rather than dive under the car. Yet for other people, they enjoy the OCIs, and don't consider their time a "cost" but rather a pleasure (I'm one of those people).
Just comments, overall. Your UOA shows fine lubricant and engine performance. Only question is: are you getting your money's worth?
