Originally Posted By: stephen9666
Originally Posted By: dirtymudder
Back some years ago I bought 2 12 volt drills where I work. Back 5 years ago all of the batteries were going bad. I took it to the local Ridgid repair center and they had to order the batteries but all were covered under the "warranty". I tried last spring to get one replaced because it would not hold a charge. The guy at the repair place said good luck. Ridgid is not covering much of anything. So I called Ridgid and they said they had no record of my purchase. After banging my head against the wall I finally gave up and took the battery to a local battery shop and got it rebuilt for $38. Good luck on the psudo warranty.
When you get batteries replaced you also have to register the new batteries, I've read online. If you don't do that, the new batteries aren't covered under the lifetime service agreement.
True.
HD said that the battery will be replaced at an uthoeized service center, that's in the next town, about 45 minutes away.
It will be an over the counter exchange. The service center confirmed this, but told me they do not have a replacement in stock, at the moment but will phone me then one arrives on Wednesday or Thursday next week (this weekend is a Holiday weekend, so it throws things off)
All I need is to show my registration at time of pick up.
I will need to re register the new, replacement battery in order to continue with the lifetime warrany.
Fortunately, I have two other batteries, so down time is not an issue.
