I just did my first oil change using my recently purchased Rhino Ramps, on the '97 Accord.
I had just removed the valve cover to replace the spark plug tube seals, two of which were leaking oil into the tubes, and then idled the car for around ten minutes to check for gasket leaks.
I then asked my wife to drive the car onto my new ramps.
I have never had an easier oil change on any modern crossflow Honda. The old non-crossflow head engines had the oil filter placed for easy access.
It was a piece of cake to remove the filter.
I had previously placed a piece of 2"X8" on the driver's side and backed onto it to raise the car enough to wriggle under far enough to get to the filter.
I have done this with both of our Accords for years, and have done the same with the BMW to get to its drain plug.
A true PITA!
With the ramps, everything is really easy.
I should have bought these years ago.
A true PITA!
