Recently I got on a reverse flushing kick to restore heat to my 95 Camaro (150k). The heat warmed the car, but it was not scorching by any means. So I pulled the heater hoses off the water pump and rigged up a neat little job with a garden hose and forward flushed, then reverse flushed the core about 10 times, until I got bored. With everything back together, topped off, bled, etc, the heat is now extremely hot, the way it should be.
In a similar vein, I decided to do this to my other vehicle, a 93 Caprice (206k). Results are not as impressive as the Camaro, but things did improve. It still exhibits a "problem" where the heat isn't as hot at idle, then gets really hot when RPMs pick up. Last year I replaced the radiator and water pump and it still did it.
On both of these cars I have tried RMI-25 as well as a Jiffy Lube forward engine flush (uses the engine's water pump). Both of these things have made marginal, if noticable at all, differences. The thing that made the difference in the case of the heater cores was forward then reverse flushing with a garden hose. On my Caprice, with the heat getting cooler (but still hot) at idle, I am thinking that the engine/intake cooling passages are the remaining ones that need a reverse flush, since the heater core gets its feed off the back of the intake manifold. Other than attack it with a garden hose, is there anything else I can do? Maybe a really strong flush chemical?
