Retaining Agent
MolaKule
Staff member
Iowegia - USA
This substance is an Olefin copolymer that is useful in release agents, and in applications for retaining oil films where inertial conditions are present.
What is the functional name for this substance?
Guidelines for the Question of the Day:
1. No Piston Cup Lapel Pin will be awarded to the same person within 14 days of a previous award.
2. Please respond with a complete sentence.
3. Please do not post links. If a question arises as to the need for clarification, then sources and links may be requested.
4. Please, no off topic posts.
Functional names for additives are listed here:
Antifoamant or foam inhibitor
Antioxidant or oxidation inhibitor
Anti-Wear
Extreme Pressure Additive
Demulsifier
Detergent
Dispersant
Emulsifier
Friction Modifier
Metal Deactivator
Oxidation Inhibitor
Rust Inhibitor
Pour Point Depressant
Seal Conditioner
Surfactants
Soot Control or Soot Inhibitor
Tackifiers
Concentrate on the latter hint:
"...applications for retaining oil films where inertial conditions are present."
Tackifiers are copolymers synthesized from specific ratios of ethylene–propylenes. Tackifiers can also be blends of PIB with ethylene–propylene copolymers.
Tackifiers are used where you want stickiness or "cling" imparted to a lubricants such as ways oils, bar and chain oils, and in greases.
Since OVERKILL posted the first correct answer, he is the proud recipient of the Piston Cup Lapel Pin.
Originally Posted By: Warstud
My second guess: Extreme Pressure Additive
Don't I get anything.
