The rear brake line on my fairmont rusted out the other day. I replaced it, then bled both rear brakes. the pedal still didnt feel right so i decided to bleed the front brakes too. the master cylinder is split into 2 sections. 1 section holds fluid for the front, the other section holds fluid for the rear. While bleeding all 4 tires, fluid came out of the rear side reservoir only. There is absolutely no air in the system, and the brake pedal still does not feel as good as it did last week.
Im assuming the valve thing underneath the master cylinder is the culprit, i just dont know how to "fix" it.
Can anyone help?
Can anyone help?
