Replacing only distributor rotor but not cap
Silicon Valley
When I replace both last time, I noticed that the cap terminals have residues but the rotor has white powered coating on top. Since most plugs that I have replaced seems to have worn tip rather than ground, can I assume that cap/rotor wear the same? that sanding off the terminals on the cap and put new rotor on will be sufficient?
The application is 95 Corolla, and the cap/rotor has been used for about 60k miles.
If it was my car, I would replace both since it has 60K miles.
I noticed on Hondas, the cap & rotor gets dogged within 40K miles.
How does a cap/rotor wear? Is it oxidation or is it lost of material due to arcing? Will sanding off the oxidation help?
Depends. There is a very high concentration of ozone internal to the cap. Oxone is reactive. Many manufacturers put a coating on the end of the rotor and the internal cap terminals to resist corroding due to the arc and the accompanying ozone. If the original cap/rotor was uncoated, don't worry about it. If it was originally coated there is a small chance wear will accelerate after cleaning. A cap terminal or rotor doesn'r have to be shiny to conduct well.
So, how do you know when to replace it? By the miles? By resistance? By Gap? or by look?
I cleaned up the cap and rotor about 2k miles ago with 800 grit sandpaper, and the engine ran smoother for about 2k, then now it is back to original, and I started seeing a lot more deposits on the cap terminals and the rotor terminals look darker/oxidized.
The new rotor has a white coating that the old one does not have (or maybe it is already worn and is now grey/black looking, with coast texture). Some people said replace it every 30k, is it true?
Short on money or for discussion's sake?
I would feel pretty pleased if I got 60k from a cap and rotor, and would replace both with the same brand as those. (OEM, presumably?)
Both. I am $600 short of each month's mortgage until my bonus come out this year. Just got an unexpected expense (wedding related). Since I am doing everything myself and can replace the cap/rotor during lunch time in the parking lot, I feel that it is better to "save the environment" and a few bucks along the way if I can.
Already sanded once, so maybe not a good idea to keep sanding every month.
if the engine is running ok and the rotor's tip isn't erroded then just sand off the oxidation and keep on going.
replace it when you have a few extra bucks. the numbers for replacing wear items are arbitrary anyway.
Interesting, I replaced my cap and rotor after 75k miles and both looked brand new.
John
