replacement battery clamp / terminal
Looks like that will take care of the positive and negative clamps. I like solder clamps for car batteries, it helps with corrosion. I've never used that style before, but at least you are avoiding the junk crimp/ clamp on style.
Where do you get solder ones? I have one large and two smaller wires
It might look cheap but just about every OEM manufacturer has switched to the stamped metal battery terminals. Imports were first but now Mopar and Ford also use them on their cars & trucks.
Dave
Exactly what do you use to solder these?
Pics?
Pics?
Pre sized solder pellets.
Here is a video on how its done.
http://www.youtube.com/watch?v=SXDkNMDDrBs
Originally Posted By: Donald
I checked a second time with dealer and they have a repair part for the RH side for $14.
It might be similar to what NAPA lists.
My package from an online order from a Chrysler dealer was a box of ten(10) universal clamps for a side terminal battery. They called that a clamp repair kit. I said I wanted more than a universal clamp. OK, I got more than a universal clamp, I got 10 of them when I ordered one.
Pics?
Although I do appreciate the advice, it's unclear to me as to exactly why I would want to use a pellet when I have over a pound of solder already.
Which I would assume would work just fine.
Pics?
Do it however you feel like doing it. You asked how its done and for pics, I provided you with a youtube video. If you want to use something different, go ahead. Lots of times the pellets come with the clamp.
Originally Posted By: bmod305
http://www.napaonline.com/Catalog/Catalo...1192_0099688186
Repair end for Mopars from Napa.
Dave
OK, I got this from NAPA. It hopefully is exactly what I need. Its got 2 slightly different sized secondary wires with butt connectors crimped on one half. And for the primary (large) cable, its a butt connector where you slide in the stripped wire from the vehicle and tighten an allen screw and slide over a plastic insulator.
While I realize many car makers are using them, the actual battery clamp looks cheap. But if this type of clamp was already on my truck, I might not be replacing it.
However the best battery test with a conductive battery tester is when the tester's clamps hit lead, not steel. I was told that by Solar company.
