I cannot figure out how to remove this bolt in the picture. It mounts the back of the generator to a shock absorber mount. It runs through the mount to under the mount by at least one inch. The head of the bolt is in a slot. If the generator could go in the bolt head would slide out of the slot, but that cannot happen.
The mount is not attached but because the bolt goes below the mount and frame you cannot slide the mount out.
