Removing Catalytic Converter = Better Gas Mileage
Glendale
OK, here's a serious solution to the rising gas prices:
Replace your catalytic converter with a stainless steel straight pipe and watch your MPGs soar. If you want to take it a step further, remove your pre-cats (if your car has them) and also remove the stock airbox and get a K&N air filter (or aftermarket intake) as well.
I did this fix on my Mitsubishi Eclipse GT and I'm consistently getting 25-27 mpg (10% highway) which far supercedes the EPA estimated 20 mpg. Try it, it works!
Oh and if you need to cheat OBD-II emissions testing: Place a spark plug non-fouler between your secondary O2 sensors - it will cause a "cooler" reading, tricking the sensor to think the cat is still there - it goes by exhaust temperature to determine if the cat is functioning.
Originally Posted By: simple_gifts
You could just slow down.
I always keep my speeds around 50mph - which is optimal for fuel economy on this engine.
Huh???!!? A temperature reading???
IIRC, an O2 sensor is effectively a solid oxide fuel cell, and thus produces a voltage (its reading) based upon oxygen ions present in the gas stream. Problem is, the ceramics used are only conductive at high temperatures...
So temperature enables the electrochemical reaction to occur... but temperature is not what the sensor is reading.
Someone please correct me if Im wrong.
JMH
JMH
Gotcha, that makes sense.
In any case, placing a spark plug non-fouler between your SECONDARY O2 sensors and the insertion point has prevented a SES light for thousands of miles on my car.
I don't know if it is helping the gas mileage, but I removed cat. #2 on the SX4. Not the pre-cat, as the O2 sensors have it surrounded, and I didn't know "how not to" throw a code.
I also replaced the stock intake box with a more direct CAI type intake. I did retain the stock air filter though, because of my fear of elevated Si values.
On a Crown Vic, leaving the pre-cats but pulling the mains yields nearly a 40 horsepower gain according to a guy I know who specialized in "upgrading" ex-cop cars.
He had some extremely fast rides.
I know on a lot of vehicles if you pull the catalyst, the ECU reads it as out of range for a certain amount of time then goes back into closed loop off the signals it does get regardless of the idiot light. A guy I know does that to his late model work trucks.
On my ex-Nissan Spec V, the pre cats were made into the exhaust manifold and had a nasty habit of coming apart and being sucked into the engine.
Cleaned them out (for off road purposes only). Perceived horsepower up tremendously. Mileage a little better, probably would have been even better if not turning over the tires in first and second gear.
on my mustang o put on a offroad (no cats) Bassani X pipe. the stock midpipe was a H and had 6 cats on it. sounded a lot better. gained a decent amount of power. also the gas mileage gains werent there, but i tended to get on it a lot more without the cats.
o and if you have a ford, you can buy MIL eliminators that plug inbetween the cat monitor and the wiring harness that trick the computer into thinking cats are there. you can also turn off the cat monitor in the PCM with an aftermarket dyno tune.
A Crown Vic has about 200 Rear Wheel HP stock - yes even PIs.
So your friend told you deleting the cat yielded 40 HP? Tell your friend he's full of it.
A cat con that is working normally has very little effect on a car's HP and in turn MPG.
I've had my Miata on the dyno as well as having dynoed other Miatas and the ones with working cats gained only about 2~3 HP without the cat. The ones with plugged cats (like my car) gained 10~15 HP without the cat. This is all on Miatas that were being boosted to almost twice the HP from stock.
The bottom line, removing the cat has very little (positive) affect on performance. If you want your car to stink like rotten eggs and have an annoying CEL, go for it.
Different cars are different. My TL uses 1200 cell precats I believe and a 300 cell single cat. The exhaust leaves the head (only one exhaust port) and makes a 90 degree turn in the course of about 1.5" straight into the precats. Deleting all three shows close to 30hp at the wheels and about 4mpg. My third cat is gutted and I just ordered the precat deletes.
On the GN, there was no single cat that flowed enough. I tried a Random technologies cat and lost 8psi boost and 10mph through the 1/4.
Originally Posted By: Jonny Z
No one mentioned the pollution?
I thought about it, but after so many internet p*ssing matches, I have tired a bit and realized there is little point with some topics.
THumbs up! :) Most Modern cats are not worth a lot of HP unless they're clogged. About the only thing they're worth is at least $50 on ebay each :)
Poor Crown Vic. SLow POS :)
i honestly didnt care about the pollution. when i had hte cats on the car literally blew 0's on the CA emissions test. when i had hte offroad pipe on i was a gross polluter, which means 3x the maximum limit.
Don't worry about that! Worry about the Federal law that says that you cannot tamper or remove a cat even if you do not have emission inspections.
The fine starts @ $25,000.
It's all about the burden of proof:
They can't prove someone deliberately tampered with emissions equipment. There's also such thing as catalytic converter failure and there's no lawful obligation that it has to be "repaired" using OEM equipment - although there may be such a law in Cali. Furthermore, catalytic converter theft is becoming a very common crime and who's to say you're required to pay $1200 for a brand new OEM cat?
And lastly, the feds ain't getting their dirty hands on someone's car without a warrant - it's not government-owned property. We don't live in a communist country.
Burden of Proof, what?
The proof is something that was suppose to be there is now gone, those straight pipes didnt put themselves in there.
