2007 Yukon Denali w/211k mile 6.2L L92. It doesn't leak or consume any oil. 81k miles ago in 2018, I did a piston/combustion chamber soak, rear main seal, & TSB 10-06-01-008M when we bought the vehicle. Rings were stuck when we bought it.
Its been 11k miles since the oil pan was last off/cleaned-out last August (not 11k on oil).
To clean the the internal surfaces that I can't easy reach, I've been running a mixture of 50% Valvoline Premium Blue "Restore" 10w-30 and 50% Mobil1 FS Euro 0w-40. This is the 3rd oci and the 3rd summer in a row that I've dropped the oil pan to see/clean-out debris that the oil is removing. Pics below. This time there wasn't much debris, so I won't be pulling the pan in the future for inspection/clean-out.
At next oil change I'll switch to 1 of 3 oils I have, either Amsoil, HPL, or Valvoline Restore and Protect? to be determined
here's the debris from last 3 pan drops:
@Brian123
@Brian123
