I have a 99 1.8t vw passat with about 80k on it. I have been running the amsoil bmk-11 bypass for the last 5k or so.
I recently (after the bypass) installed dakota digital oil pressure and oil temp. gauges. With the bypass on I was getting 12-13 psi at hot idle (200oF). Now this past weekend I removed the bypass filter and got 20-21 psi hot idle. This is certainly a significant difference.
My question is is there anyway to reduce the flow to the bypass filter to cause less of a loss of oil pressure? How much of a drop in oil pressure do you think is safe for this engine? Keep in mind this is a sludge prone hot running turbo motor.
Thanks
Thanks
