I searched the board but could not find the answer, so here goes!
I have a 1973 455 pontiac engine block. I have installed headers, which results in VERY limited clearance to get the oil filter in the stock location. I have to dent it up some just to force it past the header pipes. Obviously not a good thing! not to mention heat from close proximity to the headers.
So, hence the need for a remote filter setup. The question: whether to go with single or dual remote filters! I have seen both, and I have some thoughts on each.
Two filters: if they are both high quality filters, they SHOULD always each filter to the same micron level, so the second will in theory just be filtering clean oil. This would result in needing the first filter in series needing replacement sooner. This would probably have more oil volume, which is good for longevity and temperature, but there is more potential for restriction in oil flow when passing through two filters.
One filter: Probably less volume, although I can put on the biggest one the adapter will allow. Perhaps not as cool because of less volume and less time away from the block for the oil. But, less potential for flow restriction I would imagine. This would obviously be a very good filter, such as a K&N.
opinions please!=) Thanks. oh, and I am here because Patman has told my club over and over we should come here for oil questions too, instead of just asking him all the time.=)
