Two comments:
1. The lower fuel efficiency of 2-5% on a 10% ethanol blend is offset by the 25%+ reduction in Carbon Monoxide, as previously pointed out. In that respect, the emmissions idea is not a wash, but a positive on the ethanol side. It did actually work as intended in many areas to reduce Carbon Monoxide pollution. So well in fact, some areas eliminated emmissions programs as pollution reduction goals were met (the Twin Cities is an example of that).
What would be more interesting is the review what comes out of the stacks at the refinery level of gasoline vs. ethanol. Several plants here were tested and some pretty nasty things were found, which was a surprise.
2. As far as the energy balance goes, does anyone think no energy is used to produce gasoline? I've seen studies that show gasoline has an energy balance of around 0.75 (ie: more energy is consumed to produce gasoline than the actual final product contains). Ethanol is somewhere between .8 and 1.4 depending on which study you believe. In any case, its better than gasoline.
Don't believe me? Go look at all the powerlines around a refinery and guess who's using the electricity and where it came from!
