Refilled a floor jack with JD Hydro oil
State College PA
Like the title says...I have this 15 year old floor jack (unknown make) and I used some John Deere hydro oil that I had laying around. Filled the jack through the fill plug and bled it. It works awesome now. I can raise it to max height and it holds. So my questions is: Was this the right oil to use in a floor jack?
Hydraulic jack ,hydraulic oil ? HMMM Though it may not be the proper oil it is close enough. I use any oil around the shop for my 30 year old floor jack . They are tough.
Just about any mineral-oil based hydraulic oil of 6 to 10 cSt will work in a hydraulic floor jack.
In cold weather, ATF's will work in a pinch, althrough they do not have the level of AW additives of an AW hydraulic oil.
I've never seen a hydraulic oil as light as 6-10 cSt in the temperatures of interest ... the ISO ratings are at 40C, and the lightest I NORMALLY see is 32, with 22 and 15 available on special order. Can you give an example of one you would use?
I know that there were some ATFs, Mobil 1 in particular, that pass the Vickers and Denison wear tests. I used to recommend it in applications where start up was required in cold temperatures. It does not appear to be currently tested (or doesn't pass) based on the data I see on the web. Oh ... 36.3 cSt at 40C ...
ISO 15 AW HO is about 4.5 cSt, ISO 32 is approx. 6 cSt.
The JD Hygard should work just fine. Coastal HO up to ISO 68 should work as well.
Yes, but here we're talking about a simple hydraulic mechanism with seals possibly made in China or elsewhere of questionable materials.
I had a (Chinese made) jack fail one time because I used a synthetic hydraulic oil. Upon teardown, the seals had become degraded by the oil. Luckily I wasn't under the car at the time and was simply jacking it up to put floor jacks underneath after removing the hydraulic jack.
Be careful out there!
