Redline vs. M1
garageman402
$100 Site Donor 2026
Sometimes NorCal., Sometimes ATX, USA
Maybe this has been re-hashed a lot, but I have been searching past threads (a lot, back to 2002/2003) and I don't know if this has been covered.
Mobil 1 (the common variety that is found at Costco for $30 a case), touts itself as 100% synthetic, which I thought was a good thing. I have read that just because an oil SAYS it is 100% doesn't mean it IS 100%. There is an additive package that needs a vehicle to carry it, and that vehicle is conventional oil. The percentage of conventional being as high as 20% has been mentioned. It has also been said that if you read the label it says 100% synthetic base stock, exclusive of additives. I think this has been removed from the label since then. Now the "new, improved" Mobil 1 has twice as much synthetic as before. How can you get twice as much, if you already had 100%? I also read somewhere that if a product is 51% "something", you can call it "100%" or "fully" of that "something".
I started searching for synthetic oils on the web, and found two major companies, Redline, and Royal Purple. Both seemed about the same, but I came down on the Redline side, if, for no other reason, they are a local company (S.F. Bay Area). I am partial to Chevron, too, as I have heard they are the one oil company that puts the most into R&D. No one does more research than Chevron, I have been told. I was disappointed that I could not find a Chevron synthetic oil on the market.
I ordered 3 gals from a mail-order high performance supplier (starts with J) and when I got the bottles, saw no API logo on the side, just a statement that the oil is "Recommended for API SM/SL/SJ/SH/SG/CF" . Now I'm worried..... I happened to be in Benicia one day, so I stopped in and asked a few questions. The rep said that to get API certified would increase the cost (as stated in the AMSOIL link), and they would have to LOWER the performance of their oil to meet the standard. I presume that means less ZDDP, and phosporus (maybe), to avoid cat contamination. I also asked about cleaning, and would I have to run a flush to prevent and deposits from getting knocked loose, he said no. Another question was the additive package, did they use a petroleum-based carrier oil? He said they are such a small operation, they put the additives in during the refining process, no carrier needed.
Mobil 1 has gone up in price at Costco lately, it was around $26.50 per case (6 qt), now it's at $30.00. I got the Redline for $29.99 in 1 gallon jugs. So for the added price of $1.50 a qt., am I really getting 100% synthetic base stock oil, with all the high-performance additives? Can I safely go a 10K OCI without fear? I did flush out the old conventional oil by running one quart in the crankcase for about 1/2 hour, so any residual is gone. New filters both times.
Any comments? Is the M1 really not all it's advertised? Is the Redline really that good? Thanks in advance, and I apologize if this has been covered in a previous thread, and I missed it.
-Bob
This something that I have been trying to learn as well and it would appear that based on the pour points listed on the back of the bottle, some M1 don't even list the pour point temp anymore(at least 5 diff weights) as I noticed today in Walmart as I was returning some 5w30 that I just purchased.
under the heading your miles may vary. I have been learning a new respect for Amsoil and Redline, but have decided to go with Amsoil based on it being PAO and not that hydroscopic, I tend drive some vehicles short distances and the Ester used by Redline doesn't like that too much (or so I have read). M1 is about $6 a qt and amsoil or redline aren't much more than that and if they provide better protection for my vehicles then its cheap insurance in my mind for the driving that I do on the road and the track.
rob
Quote:
Mobil 1 5w30 at my WalMart is $22.97 for 5 quarts or $4.59 per quart.
Quick with the math I see, but I was talking in generalities of the qts that are on the shelf, since he was buying a case of six at Costco for $6bucks at new pricing
Two very different oils in formulation, target market consumer and performance priorities. IMHO.
I would rather use Redline oil"Than Mobil 1", And if some one would buy it for me I would without any reservations do 10,000 mile oil change intervals. I doubt anyone will supply me with lifetime Redline so I use Chevron products Delo 400 in my wifes Super Duty diesel, Redline gear oil "requires syn. My 2006 Toyota truck, Delo esi gearlube and Chevron or Motorcraft engine oils all at mfgs oil" not severe" change intervals . I really think syn oils are waste of money unless required.
I have to disagree with you, Steve. If for no other reason, the increased fuel mileage pays for the oil, even if you change every 3K.
I was running Chevron 10w30 in my '91 Camaro (just a 3.1 V6, man trans), and averaging around 19 MPG. I would not run a lower viscosity petroleum based oil, but the synthetics have a better shear rating, and the bearing film strength in a synthetic 5w30 is equivalent to a 30wt oil.
I tried Mobil 1, if for no other reason, because it is sitting next to Chevron at Costco. The Chevron was about $1 a qt, the Mobil about $4.50. A 5 qt. oil change costs $22.50, as opposed to $5, so it's $17.50 more. I used a 5w30 in Mobil 1.
My fuel mileage went from an average of 19MPG to 21MPG. This is an average, and I may be off a little due to driving conditions, but I know with the old oil, I never got over 20. Let's look at the numbers:
3000 miles @ 19MPG = 157.894G @ $3.00/G = $473.68
3000 miles @ 21MPG = 142.857G @ $3.00/G = $428.57
The $45.11 savings pays for the more expensive oil, plus if the synthetic is indeed more protective, a bonus, plus if you extend drain intervals, even more savings.
I actually got it because my wife was driving her mini van 10K between oil changes, and I figured the extra protection would be needed there.
Just my
Bob
Actually, the new pricing is $5 a qt., not $6 ........ ($30. for 6 qts = $5 ea.)
