Redline or silkolene
atlanta
Ok so i know im probably splitting hairs but i want to use the best oil for my bike.
I have a 2017 suzuki m90 with 1500 miles on it. I used suzuki performance 4 and a suzuki filter for the first 600 miles and again till now. I wanted to change the oil and filter at 1500 to get last of breakin metal out of the system then switch to a good synthetic.
I used redline (mostly due to friends recommendations) in my previous bike but have been told by some that silkolene is better.
I know the people on here know alot about oil so thought id get some opinions.
Fyi the m90 is wet clutch and suzuki recommends 10w-40
I put 83,000 miles on a 1999 Suzuki VZ800 Marauder (The C50 replaced it)
I used nothing but cheap 15w40 HDEO.... usually Super Tech.
Best oil has many things to consider in a bike. Does the motor share the sump with the clutch and transmission? If so, go off the Allison list for oils tested in off-road equipment with shared sumps. They are tough oils and that is what you need. They also do not harm clutch materials
http://www.allisontransmission.com/parts-service/approved-fluids/off-highway-fluids
