RedLine Oil as a cleaner
Quote:
Quote:
Ditto. Auto-RX will get your 80k engine very clean. Just be sure to use conventional oil for it, don't waste your PP!
WAIT A MIN!!!
I thought using PP with Auto RX was prefered. I remember reading a post from Frank that said something about the current Castrol GTX "sludge fighter" not being ideal, and that PP could be used in its place.
Yes, you can use PP. But it's a bit of a waste since you'll be draining it rather quickly.
If you are crazy, you might try using HDEO and changing the oil every 3 weeks for 8K miles and taking before/after photos.
No its a 04 Hemi Ram without the MDS. At the time Chrylser wanted 5w30 used. Its got 80Km on it. I am just going to use Pennzoil Platinum 5w30 this time. Maybe next time I will try something differnt.
Quote:
Quote:
WAIT A MIN!!!
Edited to add this DIRECT QUOTE from Frank:
Quote:
Straight Castrol GTX non synthetic oil & Auto-Rx works great on 99.9% of all engines( you may not be able to find Straight Castrol if it has "Sludge Fighting Chemistry"on label pass) and go on to Group111 Oils (Pennzoil Platinum) always stay with OEM specs for oil visosity.
Found in This Post, Click HERE
Quote:
Now come on..where does that come from...? Who has quantified how many OCI's of redline it takes to "make a difference?" Terry has said it would take 3 changes to level off wear metals, but....
I don’t have photo evidences as we also don’t think Red Line will have such cleaning effect, the reason my friend use it on his GDI engine is apparently the high heat his engine is generating. He used to be using Castrol RS 10w50 fully syn.
After effect over 3 OCI of 10k km (Red Line 5w40) was the visible cleaning of brown varnish inside his valve cover. We were very surprise that the cam and valve spring were silver & bright again but that took 1 ½ yr 30k km though.
I’m just sharing our experiences that ester base oil do clean but maybe not as aggressive as what we would like or fast as Auto-RX.
Quote:
Well its done. Pure PP in my Hemi. Thanks for the Help. I plan on going 10k on this oil.
Hollywood, I hope that you back your run of PP up with a
used oil analysis at 5 or 6k, and not wait until 10K. It's best to ease
into such things as extended oil change intervals.
Example being my 03 Explorer. I waited until 9K to run
a used oil analysis on Mobil 1 Extended Performance 5w30. The numbers were not impressive, and
Blackstone suggested that my car didn't like extended oci's
Maybe your Dodge will love PP (I hope so) but engines don't
always get along even with good oils.
Best of luck...
