Originally Posted by JPowell490
Originally Posted by 02SE
I had a 2000 ZX-12R on order, until Germany's Motorrad magazine testbike hucked a rod through the cases, and the release was delayed for months. Eventually I bought a 2002 ZX-12R, then a 'Busa. Anyway in my heavily modified 'Busa I'm running Motul 300V 4T, in 15w50. Same in the modified S1000RR, and Duc V4 Speciale. A close second is the Redline M/C oil, but I've only tried that in the 'Busa. The BMW and Duc both went from the factory fill, to the Motul 300V 4T.
Anyway, so my opinion gives a slight edge to the Motul 300V 4T, over the Redline M/C oil.
Appreciate that feedback. Motul it is! Any concern over the 300v not having detergents? Not that it would matter much with a 2 to 3k change interval.
I don't know who told you it doesn't have detergents. It keeps my engines clean as can be. On the 'Busa which is much larger displacement than stock, and overall in a much higher state of tune, the stresses on everything are much greater than when it was all stock. The oil is still holding up fine and the shifting is as smooth as can be, when I change it typically at the end of every riding season. Mileage on the oil varies, but typically it's pretty close to 3k miles. I could run it longer, but I like to park the bikes for winter with fresh oil in them.
