Red Line SM?
MTL, CANADA
I picked up the last 2 quarts of redline 5w30 for 3.73$ each on clearance at canadian tire. Sump takes 4 quarts on a change, and I cant find any other bottles of redline anywhere...so im thinking what should I mix it with? I have a jug of 5w20 PU but id likely want to use the PU all in one change..so any thoughts as to what would be the ideal oil to use it with?
anything you can get for cheap
PU is probably okay.
As already suggested, either Chevron or Pennzoil Conventional is more than adequate for blending with your Redline. As long as you're not blending with some high mileage oil which is said to contain their own peculiar esters which shouldn't cause any problem but quite possibly not optimal.
IMO any of the following is a no brainer for blending with your Redline:
Quaker State Advanced Durability or Motorcraft Syn Blend or Pennzoil Platinum or Quaker State Ultimate Durability.
