O.K., I am putting on my nomex under garments!!! I have decided to try Royal Purple Max Gear 75W90 in my 2003 Camry 5-SPD. I currently have OEM fill at 11,000 miles. I decided to try it instead of my old standby MTL/MT90 blend!
59Vetteman speaks pretty highly of this and the 15W40 Long Rider so I decided to try it. I will let everyone know if it is anything like MTL. Even if it is not as good as MTL it has to be better then the OEM fill. It (OEM fluid)has poor cold temp propertys and it causes a lot of drag until it warms up in the winter.
For anyone interested RP claims that it is GL4/GL5 compliant and that it is non-corresive. It also has limited slip additives already in it wich migh cause problems for some manual transmissions. I know on TOyota Trucks it does not matter but this is my first fwd Toyota car so we will see. If the synchro's are as agressive on their car transmissions as their truck synchros then this will not matter at all.
Someone was asking about GL4 gear lube for the rear of their Land Rover. THis might be a choice for you!
