recommendations on battery heat deflector insulation?
hey all i put a larger battery into my vehicle. running a 24f now rather then a group 35 and the stock battery heat insulation for my toyota doesn't fit. i know i could just cut it and then tape it and leave the gap but thinking of doing something a little better
was thinking of buying some heat reflecting type of foam / insulation / tape and wondering what people recommend?
not sure if this amazon stuff is any good but i found this below
https://www.amazon.com/WISAUTO-Alum..._cr_arp_d_product_top?ie=UTF8#customerReviews
thanks
The insulation isn't going to save you from ambient, but will likely reflect some radiant heat - so I would just cut it and leave the gap on the non engine / outer fender side. But hey, if you want to go all out, why not. 🤷‍♂️
They also sell these:
If you want a cheap/free way to make some insulation just use those old windshield reflectors that you may have just lying around in your garage if you're like me and cut it up and use some wire to tie the ends.
  • Love
Reactions: D60
ty i saw those but dont wanna spend $30 ahaha was hoping could get it done for $10-15, and yeah makes sense but the one that came with the toyota seems like just foam, it does not seem as good as this reflective alumninum stuff but maybe i don't know much
ty! sadly don't have those laying but was thinking like that type of stuff
was also wondering of just finding a vehicle that takes a 24f battery and buying there oem blanket thing
^ Yes that's one option but I'd imagine that most OEM battery insulators cost at least $30.
How about a pull from a junkyard vehicle?
i like that idea but the more i think about it seems easier just to cut my old one and tape errr or zip tie ahahahah
I have seen the batter insulators on some cars, Subaru I think. By the time I replaced the battery the insulator was best or mouse chewed. Not sure how much good the battery insulators really do.
Mine fell apart the 1st time I changed the battery 3 yrs ago. I never replaced it and have had no issues, maybe I should
