Recommendations - oil in coolant
Alamo, CA
Besides fixing the source- should I just flush this , chemical flush,or drain X times to get oil out that may harm the rubber hoses?
Unless there is evidence of corrosion or hard water scale buildup in the radiator, multiple distilled water flushes will be good. But, pull an oil sample and have a UOA done if you haven't already changed the oil. You need to find out pronto whether there's glycol contamination present. You may have a blown head and/or intake manifold gasket. What make and year car?
I used simple green and water to get mine cleaned out but then again it holds about 9 gallons and I wanted to make sure it wasn't leaking before putting liquid gold into the radiator. I did this about 3 or 4 times and about 15 hours of run time to get it this way and it worked great with no foaming and no harsh chemicals.
The source is a blown head gasket. Oil in coolant/ coolant in oil both at low levels. I'm fixing the head. This is to deal with oil present in the system for a month.
