My friend recently purchased a mint 91 Caddy Deville. It has 130000 miles; obviously easy, well cared for miles. It is driven mainly in SD and MN, 50/50-city/hwy, with occasional trips to CO, NV, TX, etc. As with most Caddy 4.9L OHV V8's, it has a slight main bearing thump, which has been said harmless. Those that don't like the thump are encouraged to try different oils, possibly even thicker. The thicker oils seem fine, with the exception of putting strain on the distributor drive gear. He is annoyed with the main bearing thump and has used Valvoline All-Climate 5w30 (dealer), which has allowed the most noise. Currently, it is on the second change of MaxLife 10w30 5qts + ML 10W-40 1qt. It has helped, but the thump/knock is still present. He was going to switch to Mobil 1 10w30. After discussion, he is seriously considering Mobil 1 Truck&SUV 5W-40(Delvac-1). Or will a combo of Mobil 1 10w30 + 15W-50 be a better choice? Is thicker really better in this application? It calls for 10w30 preferred, but 5w30 is recommended for temps <32'F. Maybe a good 5w30 for the winter and 10w30 for summer is best? All advice and comments are welcome!
