Good morning all, it's been a while since I posted, though I certainly have searched and studied many many threads. I need some advice / different perspectives on a build in process. Car is a 2019 C7 Z51, NA LT1 with Katech heads and cam package. After several years of tracking, it needs a new short block (2 cylinders getting weak per leakdown test). I have a new short block on order from Late Model Engines. Pretty standard stuff:
- new GM block with LME blueprint process
- Callies Compstar LTX 4340 Forged 3.625" Stroke 8 Counter Weight Crankshaft with LME blueprint process
- Callies Compstar 4340 6.125" H-beam connecting rods w/ 2.1.." journal
- DSS RACING FORGED PISTONS - 4032 alloy - 4.070" X 1.305", -2 CC dish, .927" pin,1.2 / 1.2 / 3.0 mm ring pack [went with 4032 alloy instead of 2618 to avoid/reduce cold piston slap and hopefully have quieter street operation; 4032 is plenty strong for this NA application and a bit lighter too]
- Clevite H Series Main and Rod Bearings CB663HN
Car is used for street and track driving. It has aftermarket cats, "Ultra Green" from Kooks.
LME recommended breaking in the engine with Driven BR40, two 500-mile cycles. After that, they suggested You may then switch to full synthetic oil, any good name brand is fine but the minimum weight to use would be 10W30, and you can run up to and including 20W50 - no more 5W oil. Will receive build sheet with all clearances when complete.
Car sees oil temps typically in the 260-280 range on track. I'm in North Carolina and typically track at VIR, CMP and the Roval in Charlotte.
With all that in mind, I'm looking at Driven DI50 or Mobil 1 15W-50. I want to avoid anything with a big calcium number given this is a DI engine. HPL's Supercar 5W-50 seems to check the boxes as well, EXCEPT LME said "no more 5W".
Thanks to all in advance for suggestions, thoughts, and/or prior experience. Have a great day!
