Receiver pin was missing when I got home - only the clamp held the ball mount
Obviously you drive too slow. Which in this case is a good thing. 👍
This is probably the sticker on your Mustang, isn’t it?
My guess is someone removed it. This makes me want to pull the lock off my locking pin, and give it a good kerosene wash and relube it. It's been dangling back there for years. I always leave my ball in the receiver. If someone rear ends me, the ball gets there first.
I always use a locking pin, for theft deterrence and never liked pins that only use some kind of clip to keep them in. I've never been able to get a pin out with a trailer on, always "some" force on the pin.
Is the pin grade 8 or stronger?
I would guess it's not grade 8.
Wouldn't a grade 8 bolt with long shank tightened with nylon locking nut be the 100% fix?
If the failure mode was breakage, then yes. However, I don't believe the pin broke. If the failure mode was theft, then no a bolt with a locking nut wouldn't stop theft.
I leave them on and have used the Masterlock keepers for decades - no issues …
