Rebel 300 drain fuel tank
Not sure specifically about the Rebel 300, but most modern motorcycles do not have a drain plug. I believe the 300 is fuel injected, so the only openings in the tank are the fill cap, a vent and the fuel pump outlet. You'll have to siphon most of the fuel out, pull the tank, flip it and drain it.
No it doesnt. I have a completely dissembled CB300R in the garage.
Your best bet is to drain as much as you can out with a large syphon and run it until its dry.
You could take off the tank and pull the pump that would be messy but work. Removing the tank on these bikes isnt the easiest thing in the world.
