Generally speaking, am I correct in thinking you should change the brand and/or weight of oil you use, or maybe the brand of filter, if you notice any of the following:
1. somewhere around 2k miles into the oil change you notice your oil turning dark or black?
2. You notice your engine is developing a thin layer of varnish on it's valves or inside the valve cover. You see this through the oil cap filler hole.
3. Your oil smells bad starting somewhere around 3k miles.
4. Your engine makes small noises or sounds.
5. Your engine uses a quart or more oil in less than 1k miles.
How can you tell what needs changing?
