My point has always been that if there is any benefit what-so-ever in changing to a relatively cheap, $20/L gear oil then I'll do it. Also, there's a difference between my 305 CHP application and the base base Impreza's 170 CHP, but that's not reflected in the service manual. Is the FF really so robust that it can handle a potentially more severe service with out ever needing to be changed? Are they saying that the base Impreza's rear diff will outlast the car under normal driving, and the STI will maybe last 150k? These are questions I have, and the only answers I'm getting are based on speculation.
I'm also not doing this simply because I'd like peace of mind, although that is a big part of it. I'm asking for some one to definitively explain to me why the FF comes out looking so terrible, if it really corresponds with something negative. Some say it is an additive like Moly, but my used oil analysis shows nothing to back that up. Others say it's clutch material from the LSD, but that doesn't hold up since the T-2 isn't a clutch-type LSD. There has to be something common between the earlier clutch-type LSD Subies and my newer type, and the only straw I have to grasp at so far is that it might be excessive Fe wear.
