I'd say you could try gambling with RA & you could potentially save quite a bit. Just know it may be a gamble and if you're trying to avoid that issue could end well or not. It's not some sophisticated electrical part so you should be fine but you may just want to flip a coin. Worst case is it doesn't work out & you need to return it. RA kind of makes it tricky for their returns in my experience but others may have a different experience.Napa or Rock auto are normally my go to choices.
Rock Auto has a couple choices in the "Standard Replacement" category, neither of which I'm familiar with. USA Standard Gear and Motive Gear.
Then there's NAPA, at 2X the cost. Around $230.
