- Joined
- Apr 13, 2013
- Messages
- 3,221
My Pilot has front & rear automatic climate control and I usually set the A/C to 70 AUTO for both to let the system do its thang. The front drain always drips but I had never seen the rear one drip. I was about to crawl under the car to see if the rear drain was clogged when I decided to first manually crank the rear A/C to LO max, and VOILA, the rear drain started dripping! I set it back to 70 AUTO and then it stopped. Changing from recirc to fresh air mode didn't make a difference.
The air is cold & I'm glad the drain isn't clogged but I'm perplexed by this dripping behavior. I feel like the rear A/C system should be dripping out condensation at 70 AUTO on a hot, muggy day, like the front A/C always does.
