I am thinking of running a less-than-scientifically-sound "real world" experiment to judge the relative effectiveness of various fuel additives at improving fuel efficiency in my Burb. The plan is to run each additive for one month (~800-1,000 miles per month), with an additive-free month between each. I like to use the same pump at the same Shell gas station for every fill, which will help me get more consistent fills and thereby allow for better tracking of fuel efficiency and reducing the potential for different brands' fuel additive packages to skew the results (the 10-20¢ per gallon discount with my grocery store points doesn't hurt either). The relatively mild weather here in SoCal will help reduce differences created by varying air temps (warmer air resulting in better FE due to better fuel atomization, IIRC).
I am planning on testing the following additives:
*MMO @ 4 oz/10 gallons
*Pennzoil Marine Premium Plus TC-W3 2-stroke oil @ 1 oz/5 gallons
*Techron Fuel System Cleaner at 1 oz/1 gallon
*Gumout All-In-One at 1 oz/3.5 gallons
December will be my baseline additive-free month and I was thinking of running either the Techron or Gumout in January and the other as the last experiment additive, putting 3,500-5,000 miles between those PEA-containing cleaners.
Depending on the results, I may try out other additives after the 8+ months it will take me to complete what I outlined above.
What do you think of my methodology and does anyone have any thoughts on which may turn out the best result?
