2000 Silverado 2wd 5.3 38500 miles.
I need to change the oil, but the OLM has not lit up yet.
It is the old style OLM that does not indicate % oil life remaining. Only the "Oil Change" light comes on when needed.
Although the computer thinks the oil is good, I need to change it out due to the factor of the time the oil has been in the crankcase.
If I follow the normal OLM reset procedure, will it reset the OLM even though the "Oil Change" light has not come on?
I plan on using Pennzoil Platinum 5-30 (with $5 instant rebate) and ACDelco filter.
Your thoughts...
Your thoughts...
