Ravenol REP vs BMW LL 04 5w-30
Hi guys,
I've done an oil analysis recently for Ravenol REP. I thought to post here the comparison between REP and BMW LL 04 5w30.
The car is a BMW M2 G87 S58 engine. Ravenol REP was used for 7000 Km (including 2 track days), BMW oil was used for 6000 Km (no track usage).
Left column is voa, right column is uoa.
When i sampled BMW oil the car was 16500Km and when i sampled Ravenol the car was 28000Km.
What do you think ?
Hi guys,
What do you think ?
You're not going to like my response but IMO there are couple of problems.
No 1: These are consecutive single pass UOAs. You have residual oil in the sump from the previous fill. You need many samples from each.
No 2: The amount of km's on these samples is insufficient. These are long drain 10k mile oils.
No 3: Wear is statistically the same which is why UOA's are not the correct tool for comparing the "performance" of various oils.
What I find odd if the difference in calcium between the VOA and UOA of the LL04 oil.
Well.... i asked to see what are the opinnions of people who know more about oil than i do ( i know almost nothing about oils), so your opinion is more than welcome.
No1 : I dont exactly get what you mean: should i take a sample a 7000Km, then let's say another one at 10000 Km ?
No 2 and 3 You mean basically at 7000Km there is no important difference between these 2 oils. So if i change the oil at around 7000Km i shouldn't do an UOA ?
I would run each oil for 2-3 intervals and sample #2 and #3. I would also at least push the interval out to something close to BMW recommends for your country. In the US the interval is lesser of 10k miles(16k km) or 1 year. Note: Wear will by default trend downward as the km's accumulate.
UOAs are useful for determing whether you have a problem (coolant, air filtration, fuel dilution, bearing wear) as well as giving you an idea of how far you can take an oil.
My humble opinion.
No matter how hard you try and believe you’ll never be able to produce comparative oil quality data from a couple of $35 spectrographic analyses. It’s not the right tool for the job. Comparative oil quality testing is complicated and expensive and there’s a reason for that.
