Ravenol 5w30 REP vs VMS vs VMP
Well, you're kind of asking the wrong guy. I am a Bosch certified diesel technician and I am not a fan of pulling emissions equipment off anything. So IMO I would stick with the recommended C3 oils, but it's your vehicle.
Quote
Neither am I, but if push comes to shove I will amputate to save the patient
That said, would running a Full Synthetic HD oil like the ones I mentioned be detrimental in any way?
Originally Posted by andreigbs
Quote
I don't know the long term ramifications. I would like to think if an oil is ok for a DPF in a Ford pickup that it's probably ok for a Mercedes Bluetec, but I don't know if that's actually the case. I would suspect SAPS levels in even DPF friendly HDEO's are higher than something with 229.51 approval.
My thinking as well, with the only real difference being that on HD vehicles like class 8 OTRs the DPF is designed to be taken down and cleaned at regular intervals. Something 200k or 300k miles if I'm not mistaken (correction appreciated).
The DPF on my Bluetec however, and on all other passenger diesels, isn't designed for that even though you probably could have it cleaned if needed. It's just that the fittings, pipings, and container itself are not meant to be accessed and regularly serviceable.
But while HDEOs contain slightly more SA% than MB specs allow, I can't really imagine that a 0.02% difference is going to be significant. If anything, it may require regens more often perhaps. As it stands, current mileage interval average between regens is about 500-600 miles.
I don't believe used oil analysis are proof of much other than how the oil itself held up. But that's a debate for another day...
The reasons I'm looking at the REP is 1) it carries both MB specs 229.51 and .52 for the Bluetecs, 2) I can get 10L for $84 which means $8.40/L for excellent oil, 3) it has "racing" on the label
Could you perhaps elaborate a bit on how/why the REP makes you happy? Obviously, Ralf Schumacher endorsing it would typically be enough for me (LOL) but real user experiences would be ideal. TIA.
Tungsten acts a lot like moly (reduces friction, both bond with sulphur in various compounds). Most oil makers skip the tungsten and just use moly. I'm not sure which is better. Ravenol has both tungsten and moly, maybe to reduce friction more than just the typical moly alone. Google terms are: WS2 oil additive
and some aftermarket additves of questionable value pop up. Ravenol carefully blends their oils which is better than having 3rd party additives poured in.
Ravenol has never used WS2, it uses organic tungsten,
CAS: 1159919-46-6
name: Amines, bis(C11-14-branched and linear alkyl), tungstates
Opinions on whether the REP flavor would result in any meaningful, noticeable difference in my application vs the two domestics above?.
Probably not noticeable.
A full-PAO oil like REP should leave less piston deposits over time which is something nobody would notice unless the rings start sticking at well over 200,000 miles.
The WS2 (tungsten) and molyDTC in REP is expected to protect bearings a small amount better, very possibly. I can't be sure since Ravenol's other components affect that result too.
_20200720050021-png.25362
CAS: 1159919-46-6
Quote
REP and VMP are full PAO and USVO, and REP has tungsten which makes it slightly different and possibly better. Both have great pourpoints due to the PAO.
Thanks, this is the kind of info I need.
Could you elaborate on the tungsten and why it may be better? Answered above, thanks paoester.
Agreed on pourpoints due to PAO.
I will admit, it's pricey stuff when I can easily get Pennzoil Euro LX 5w30 or Valvoline MST Synpower 5w30 much cheaper ($5.39/qt for the MST locally).
Edit: found this on tungsten. Interesting stuff, I wonder where might one get this unobtainium from? Found the answer to this as well, now for long reading...
CAS: 1159919-46-6
Organic tungsten creates a chemical lubricating film on the friction surface of the engine, which can repair wear to a certain extent. The chemical lubricating film can reduce friction and lubricate the engine very well.
Gents,
In search of a Euro oil for my Bluetec OM651, I came across the above 3 flavors of Ravenol.
Besides the price and specs (229.51/.52), can anyone help shed some light on what would be the advantage of the "Racing" formula?
I haven't tried Ravenol yet, but if there's some magic elixir in the Racing version to improve longevity and performance in my Bluetec, I would surely be interested.
Currently at 106,xxx miles and no issues (DPF or otherwise) to report with current oil choice (yes, I read the whole 12-pg LM overrated thread, and that's what I've been using).
Thoughts please?
My thoughts are, one of the best oils that meet 229.51 and 229.52 is on sale quite a few times during the year for less than $6 a qt. Mobil 1 0w30/5w30 ESP.
There is nothing at all special about Ravenol.
Oil producers have been messing around with Tungsten since I was a kid and that was long time ago.
Seems most of the "racing" oils from Ravenol are out of stock. I've used the RUP 5w40 in my A4 alot and am coming up on my 80k oil change and cant find any.
Oil producers have been messing around with Tungsten since I was a kid and that was long time ago.View attachment 25389
The special thing about it is that it is actually what it claims to be. Synthetic PAO/Ester and an engineered add pack. Is it better than that old school Castrolite? Don't know, but it certainly isn't a modern group III declaring itself a synthetic when it really is quasi-synthetic. If there is a need for something that exceeds as far as temperature or oxidative qualities then I say go for it.
The special thing about it is that it is actually what it claims to be. Synthetic PAO/Ester and an engineered add pack. Is it better than that old school Castrolite? Don't know, but it certainly isn't a modern group III declaring itself a synthetic when it really is quasi-synthetic. If there is a need for something that exceeds as far as temperature or oxidative qualities then I say go for it. is..
Years ago that may have made a difference but not anymore. It is the final formulation that matters not the base stock.
It could also be said that anything done to refine crude oil is in some way synthesizing it.
One meaning of synthesizing
To combine (a number of things) into a coherent whole.
I just got that big book written by the Dr. about all manner of oil. I will try and quote some of his perspective about this subject soon.
The MB oil specs are high, if an oil meets the specs it doesn't matter if the base stock is old dog whiz and peanut oil with a splash of strawberry jam.
HC technology and mixing bases is so advanced now that as Trav said final product is what matters.
Now, that being said, companies can achieve what they want probably easier by using PAO or POE. Sometimes if oil is aimed at high performance cars that might see track, PAO or POE will be present in higher quantities. That still does not mean they are better than majority Group III oils. Mobil 1 ESP Formula 5W30 that was discontinued was arguably best MB229.51, VW504.00/507.00 oil available on the market. Current version is still probably best, although some performance numbers are worse than in previous version.
We have somewhat veered away from my point, labeling. Whether dog whiz, peanut butter and a strawberry jam is the best isn't at issue. If that dog whiz, peanut butter ,strawberry jam called itself a synthetic because the peanut butter was "synthesized" from crunchy to smooth is the topic at hand.
Not at all, the point is if the oil meets the manufactures spec what base stock was used is irrelevant. The days of true synthetic and earth oil labeled synthetic are long gone as far as regular engine oil are concerned.
