Rav4 kms 9000 on oil 50000kms total -0w-20
Australia
Car 2012 2.4L RAV4
Total kms 50000
Oil and filter kms 9000
Oil grade Toyota 0w-20
Oil added none
Air filter OEM Toyota
Time 6 months
Aluminum 1
Copper 1
Iron 9
Lead 0
Tin Sodium 1
Boron 10
Potassium Moly 122
Phosphors 910
Magnesium 8
Calcium 2860
Zinc 980
TBN 4.9
Viscosity at 40c' 37.3
Viscosity @ 100c' 8.6
Water% 0.1
PQ index Glycol Petrol% <0.5
Very good results, I would stick with the Toyota 0W20 for the next oil change and run to similar time and distance.
That does look great! I recently almost bought a similar vintage Rav.
Originally Posted By: bigt61
Looks great - another 3000km next time should be easy.
He's going 9000km, which is 5580 miles.
Recommended Viscosity 5w30 and 6 months service interval.Now vehicle is out of warranty and i do 6 months oil change with 0w-20 grade.
We do have followings for sale in Oz. (Mobil 1 from an importer.)
Mobil 1 Advanced Fuel Economy 0w-20.
Mobil 1 Extended Performance 0w20.
Penrite 0w-20, 0w-16,5w-20.
Valvoline 0w-20.
Fuchs 0w-20,5w-20.
Castrol Edge 0w-20 and 5w-20.
TGMO 0w-20.
Nulon 5w-20.
I really believe the 6month oil change interval is an overkill on most usage senarios.
Usually they give the 6month interval for extreme use case senarios. So pay attention if they mention 1 year for normal use.
My past experience if you change oil more frequently less oil leaks.
Engine will last long time but not the oil seals.
On these days Gasoline engine can go more than 500000kms with out major overhaul.
