Does anyone here revalve/freshen their own racing shocks? I started doing my own QA1's this year and was wondering if anyone has experimented with different brands and weights of shock oils.
as a matter of fact, i'm about to try out some new non-newtonian oil. others i have talked with say it is great.
at $100 for a single change. it better be!!! (ie that is almost 33 per qt)
What oil and how did it work?
I always used to use Silkolene Pro RSF, but haven't done any re-valving/rebuilding for a number of years.
There is a very good spec chart here http://www.peterverdonedesigns.com/lowspeed.htm if you scroll down the page.
The best fluid specs I've seen in terms of VI are blended by bruce381, so you could PM him or drop him a line.
If I was still doing any shock work I would be using the fluids Bruce blends.
That's what Redline costs downunder, so for a shock oil, sounds like a deal.
It says Product Data Sheet but there aren't any tech specs there ??
It just reads as an advertising brochure.
I won't use a fluid unless I have the viscosity at 40*C and 100*C.
OK, what sort of non-Newtonian fluid is it for starters ?
What are it's characteristics ?
Then, it will still exhibit a certain viscosity at 40*C and 100*C in an unstressed/unsheared state.
The rebuilder/revalver has to know if this fluid is comparable with the viscosity of fluids they've already been using. The 'data' sheet tells me nothing.
you are not understanding the fluids properties and therefore the question.
Like what ?
Increase the shear rate (turn it faster), and measure the viscosity...
Plot shear rate against visosity.
IMO, a machine similar to an HTHS would be easier than producing/calibrating a viscometer that was like a syringe, where you would have to include allowances for inertia and acceleration.
