Originally Posted By: asand1
Wow, so much misinformation. I was able to fill mine and start it for like five seconds at a time without running the reservoir empty. Even turning lock to lock. I think this is what Honda is sayng, to shut it off before runing dry and causing damage.
I don't know how anyone could think its OK to run the PS empty, besides, once the pump is empty there is no pressure to empty the rack.
You need to keep adding fluid in order to flush.
Perhaps you should read and quote the Honda FSM instead of speculating about what you think Honda is saying. No one, including Honda, says it is ok to operate a dry PS system. But, it is perfectly ok to operate it for the time it takes to empty the system. At the point all of the parts are still protected by a film of fluid. Personally I like to empty the system manually but I have also followed the FSM procedure and it works fine.
