Originally Posted By: StevieC
This will open a can of worms on opinions.
I have tested this myself and found that it does retain ferrous metal bits on the wall of the spin-on oil filters. Whether it made a difference in the longevity of the engine it's hard to decide because all my engines with/without have lasted numerous hundreds of thousands of kilometers. The metal particulate it did catch was extremely fine almost not even visible.
Certainly nowhere near this amount.
Do it if it makes you happy but it's probably not going to have results worth the cost of the magnets.
StevieC is dead on. Oil filter magnets catch ferrous metal particles. Magnets don't catch any non-ferrous metal particles that are also passing right by the magnets. Does it make an engine last any longer? I've read many a discussion on this subject, and I've also read all the sources that people reference. Never have I seen any conclusive evidence that using filter magnets makes an engine less prone to failure, or that they make engines last longer, or any other measurable benefit.
The only reasoning ever provided is that magnets catch ferrous metal particles. Metal can cause wear in an engine. therefore, I must be protecting my engine because I'm using magnets. But car engines go hundreds of thousands of miles all the time . . . without any magnets on the oil filter. Or the drain plug.
But if it makes you feel like you are taking better care of you car, by all means, slap a few on the outside of the oil filter. I bought some bar magnets for an experiment at work, and since they were just laying around after I was done, I now use them on my Outback oil filter. Do I believe it will save my engine from failure? Absolutely . . . not! But it's fun to think about what they are catching. Maybe it will make a difference on my next UOA. Maybe not.
