Well when you are changing the oil, pull the drain plug and let about a Quart run out and then fill the bottle. Its best to have the oil warmed up (take the vehicle for a 20 min run before changing). I would imagine the same would go if you are using a bypass setup, let the oil get warmed and circulated and pull out a sample.
Eric
BTW - What part of Illnois are you from? I travel out there quite often for work.
Eric
